Paxton SC Oil Cooler
Old Aug 9, 2004 | 02:03 PM
Kwik89GTA's Avatar
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
I am building the oil cooler system for my Paxton SN93. I have found the dipstick and a Derale twin flow cooler with the 10 inch fan. I need to have some idea of what pump to use for transmission fluid. I have tested a cheap Purolator fuel pump, it will pump the trans fluid by itself, but it won't pump through the cooler and back up to the blower.
I have entertained the idea of using a Holley Red Pump, but any ideas will be great before I jump into that....
I have also looked at www.jcperformance.com , but $350 for a cooler setup (for a POS Paxton, no less) is a little much....
Kevin
Old Aug 9, 2004 | 10:36 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I am sure you could use a gm (fwd) power steering pump. mount a small 12v motor to it or just keep the belt drive.
Old Aug 14, 2004 | 01:03 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
where did you find the dipstick tube at.
Old Aug 14, 2004 | 02:54 PM
Kwik89GTA's Avatar
eBay..... There was a mustang guy selling two Sn93s. I emailed him, and convinced him to trade me the oil cooler dipstick for my standard dipstick plus $10........ I would have gotten the complete cooler with the pump but he didnt have it.
Old Aug 28, 2004 | 11:13 AM
Kwik89GTA's Avatar
Got it...
Well, I finally broke down and bought a used Holley Blue pump. Beautiful. Primes itself perfectly, pumps a quart in few seconds, and circulates the Type F fluid fine.
Old Jun 24, 2010 | 08:28 PM
Todd Frank's Avatar
Re: Paxton SC Oil Cooler
Kevin
i have a sn 2000 on my 90 gt with a pump from paradice wheels out of Cal. The guy there you need to speak with is Craig. Their pumps are alot cheaper than your alt. rout and work fine. Ive had there set up for over 10 years without any trouble. The only complaint I have is they qiut making paxatrac fluild, so that means your down at least 5 psi of boost on reg trans. fluid.
Old Jun 24, 2010 | 08:32 PM
Todd Frank's Avatar
Have you heard of any other fluid to use these blowers to get the boost back up?
Old Jul 11, 2010 | 10:25 PM
Kwik89GTA's Avatar
WOW! Blast from the past! I started this thread 6 years ago...... I talked to Craig at Paradise wheels at the time..... too much money for it all. I'm not sure that they are still in business.
I sold the Paxton to another Thirdgen member a number of years ago.
Kevin
tyeo098
Nov 30, 2015 06:27 PM
1992Z28!
Nov 19, 2015 07:33 AM
skinny z
Oct 5, 2015 06:23 PM
CatmanFS
Sep 19, 2015 09:00 AM
apie2546
Sep 5, 2015 07:40 PM
