doing single turbo need help
Old Sep 6, 2004 | 03:16 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
i am having a single turbo kit fabricated for my firebird. Im basically starting all over i am going in a new direction. Here is what i will be starting with 87 firebird 383 block t70 single turbo
turbo 350 trans i will be reusing my holley stealth ram. my questions are what compression would u recommend 8to1, 8.5 to 1 which heads and cam,what size injectors, what size stall.
in will be running 3.73 gears in it. i am completely new to turbos so i have no idea what they like and dont like so if yall would give some ideas i would be happy. i want to build a setup that i will have room to grow with.
Old Sep 6, 2004 | 04:13 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
What application- racing or street? Any goals in mind?
Old Sep 6, 2004 | 07:22 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
a lil bit both its just a weekend fun car to cruise and go to the track the guy building the turbo kit said i could 500+ rear horsepower and still be completley streetable nothing extreme but i want it to be stout
Old Sep 7, 2004 | 12:43 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
You can do 500 hp on a stock L98 If you only want 500 hp, and will not be tempted to turn up the boost EVER, then I'd say run 9.5:1, and leave your boost at 8 psi. 15 psi I'd build it at high 8's...
Old Sep 8, 2004 | 02:35 AM
stu
Guest
Posts: n/a
I personally wouldn't go any lower than 9.5 compression. I'm sure it's different for a V8, but anything less and it'd be a dog out of boost. Besides, any forged 9.5 compression piston should be able to hold more boost than you'll ever need anyway. My stock pistons are 9.5 and I'm running right around 15 psi with over 170,000 miles.
Old Sep 25, 2004 | 02:51 PM
Aliengotpsi's Avatar
Car: 88 Trans Am, Eclipse turbo
Engine: 305, 122 ci
Transmission: T-5 , Junk
You Retarded? thought so... nothing lower that 9.5? haha
I wouldnt do anything above 9.0
Right now I run 7.8:1 with 30 psi on race gas and a 50 shot of juice on my stock block 2.0l 4 banger
The problem with running high compression and turbo is that its going to be hard to tune and will be a bitch on pump gas on a hot day, better use a knock control Its all about being safe!!!!
8.5 is like using a condom and 9.5 is like pulling out ..
Old Sep 25, 2004 | 04:13 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
9.5 is pretty high especially if you're not using an intercooler.
anywhere from 8.0-9.0 is fine.
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
dusterbd
Sep 29, 2015 08:40 AM
