what nitrous kit for my TPI
Old Sep 18, 2004 | 06:04 PM
camaro_1983_383's Avatar
I have an 87 350 TPI that i want to put some squeeze to, but what kit sounds best. Its fairly stock, mild port work, a little bigger cam. I would like to shoot around 100 safe. Its a rebuilt motor, powdered metal rods. so its stronger than stock, and runs pretty good. Im going to be bolting on some 1 5/8 primaries headers soon too. what kit sounds best and can i go bigger and still stay safe? I think a wet kit will be best, but im not made of money either. Thanks for your help.
Old Sep 19, 2004 | 09:53 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
do a search at jegs and summit and online to see whats available. i konw jegs has a kit designed for TPI engines part no. 741-05151
Old Sep 20, 2004 | 11:20 PM
I know that there are alot of kits out there, but i was kind of wondering what people thought of the power range I was looking at and whats safe. I dont have much experience with TPI or Nitrous. But thanks alot for the reply, atleast someone replied.
Old Sep 20, 2004 | 11:31 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I have the NOS 05151 wet kit and I've run 4 bottles through a 120k mile L98 with no problems @ 150 hp of a shot. Damn, that's a bad run on sentence.
Anyway, get a fuel pressure safety switch. Mine kicked in at only a 100 shot, which prompted me to upgrade my fuel pump. Other than that, you should be fine on your fresh motor. I have stock block, rotating assembly, and heads, haven't even had a hiccup.
Old Sep 21, 2004 | 07:40 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
well you should defenitly be able to run a 100 shot, 125 if you want that little more umph, and 150 if you feel like possibly taking a chance.
Old Sep 28, 2004 | 10:25 PM
thanks for the advice. Ill probly stick with 100, maybe 125 at the strip. I will definetely get a safety switch. Thanks for the advice.
stalkier
Dec 6, 2015 11:25 PM
toronto formula
Nov 10, 2015 06:17 AM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
