possibly dumb question
Old Oct 28, 2004 | 03:30 PM
jonarotz's Avatar
Car: 91 Z28
I have calculated my pressure ratio and my compressor flow for a single turbo set up. I was wondering what I would need to do to calculate these items to find a suitable turbo(s) for a twin turbo set up. Do you treat each 4 cyl. seperate?
Old Oct 28, 2004 | 09:29 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
Just divide your airflow (CFM or lbs/min) in half, and plot it on the compressor map. Use the same PR (pressure ratio) as you used for the single calculations.
Most compressor maps list airflow as lb/min- if your calculations compute CFM, you need to multiply CFM by 0.069 to convert to lb/min.
Old Oct 28, 2004 | 10:23 PM
jonarotz's Avatar
Car: 91 Z28
Thanks 89JYturbo
I just wasn't sure what needed to be dividedin half.
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
Caspar
Jun 19, 2016 11:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
