Vortech Pulleys
Old Oct 28, 2004 | 09:22 PM
adam383's Avatar
Vortech Pulleys
I searched and couldn't find anything. Does anyone know where I can get a vortech crank pulley to run serpentine and keep the v-belt? I know this is how the universal carb systems are but can not find the pulleys seperate from the kit. It does not have to be Vortech by the way any v belt- serpetine pulley would work.
Old Oct 29, 2004 | 07:31 AM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
You dont see the pully listed because they DONT give you the crank ascesory pully... You run your stock crank pully and then put the vortech crank pully on top of it...Basically it slides down inside of your crank pully...So you can run v-belt/serp or whatever you want>>>
If you want everything on 1 piece pully setup then get the dimensions of what you want and call ASP...they will make whatever you want..
Old Oct 29, 2004 | 09:00 AM
adam383's Avatar
I know they run a mandrel system but I didn't know if they offered a one pulley system or if anyone else did. Thanks for the input though.
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
evilstuie
Sep 24, 2015 02:31 AM
