Magnacharger or Eaton Fans switch ya "TV" on
Old Jan 2, 2005 | 05:35 AM
german-motorsport's Avatar
Did had some Q´s about the Magnacharger and the Ls1 swap:
Magnacharger in the 10th and a old/new 4th gen kit?!
http://www.ls1tech.com/forums/showthread.php?t=256183
Wanted some Eaton/Magna infos and this came up!!!!!!!!!!!!!!!!!
Funny things pop up when you press the search button and dont need a Industrie kit to make a M112 run!
4th gen guys read this:
Third Generation F-Bodies > Tech Boards > Power Adder > Eaton M112 Runs!
https://www.thirdgen.org/techbb2/sho...ight=eaton+m112
4th gen LT1 Eaton website:
http://community.webshots.com/album/73249682zNpxhw/1
Eaton m112 with 1000HP?
Third Generation F-Bodies > Tech Boards > Power Adder > Twin Eaton breathing air
Magna Talk ?
LS1TECH > LS1-LS2-LS6-LS7 PERFORMANCE > Forced Induction
http://www.ls1tech.com/forums/showthread.php?t=252210
Real world compares avoided??? Magna/ATI?
LS1.Com Forum > LS1 Specific Technical Discussion > LS1 Forced
http://www.ls1.com/forums/showthread.php?t=543222
Pro Talk about magna? While the backyard is running 10th with a homemade “Magna”!
http://www.toohighpsi.com/SCTC/sctc.htm
Old Jan 2, 2005 | 10:40 AM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
You missed a whole series regarding my old Malibu that duplicated Mikes T-bird setup.
While I never ran tens.. the potential was there had I put a good motor with it.
Anyways I dropped back to a single, and putting it into my truck.. <G>
Old Jan 2, 2005 | 11:31 AM
No we did not miss your twin version !
We just wanted to post against the big ignorance!
If you read careful between the lines you´ll get the point!
There is a "way to upgrade" the eaton!Evenso this takes time and work
The eaton 112m on a LS1 would be less wheigh than the ATI
The Magna/Eaton is cheaper
Put a better heat exchanger in the lower front of a 3rd gen and
run more boost !
Would like to see a modded M112 case on a Ls1 with different pulleys and real cooling system!The GTO boys are tuning there
magnas into the 490 HP zone! Imagine a tricked out cooling and Blower case like on mikes T-bird!
The industrie doesnt like any "hi-jack" try outs by the backyard wrenchers...
Both on LS1 and Ls1 Tech my Q´s were not really answered by the "industrie"...!
We will see about that! Nineball and John pretty much know more about a "better" magna in works....
the Ls1.com answer was by a ATI seller so i didnt blame him not to step in with a real world comparo on the magna and ATI!
I always loved the TPI twin unit of yours and took the time going thru mikes website and couldn´t believe what i saw....that T-bird is heavy like ...... against our 2300 pds car i bet the std Magna kit would bring us into the 10th cause its so lite !
looking at the post views i can tell that more people are standing behind the curtain looking close for the next magna kit and price
Old Jan 6, 2005 | 01:21 PM
SATURN5
did you get my mail???????????
Bubbajones_ya
Jul 6, 2024 08:32 PM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
scotrans am
Sep 5, 2015 04:26 AM
85Special
Sep 3, 2015 04:21 PM
