Walbro pump questionable?
Old Jan 5, 2005 | 06:56 PM
Fastmax's Avatar
Car: 89 IROC
Engine: 350 CI Tuned Port
Transmission: Automatic
Axle/Gears: 3:45
I recently read in a post where there is sometimes a problem with the Walbro high pressure pump when using it with an FMU. If I remember it correctly it talked about the volume falling way off at higher pressures. Is this correct? Can anyone elaborate? Is it going to feed 4-450 hp Ok?
Thanks,
Roy
Old Jan 6, 2005 | 01:03 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
See if you can find an answer here. http://www.autoperformanceengineering.com/
/N.
Old Jan 7, 2005 | 06:01 AM
Fastmax's Avatar
Car: 89 IROC
Axle/Gears: 3:45
Thanks for the link, Roy
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
