Window switch and rev limiter
Old Jan 6, 2005 | 11:03 PM
25THRSS's Avatar
When using a spark controlled rev limiter similar to what msd uses with their boxes, is a window switch really necessary? I know it is a must when using a fuel controlled rev limiter, similar to what is used on a lot of factory cars, but would it be necessary with an aftermarket spark controlled rev limiter? The only thing I could see happening is the nitrous stacking up in the cylinders with no spark, and it all igniting at once when the spark is reintroduced. What are your thoughts on this?
Old Jan 7, 2005 | 05:44 AM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Use the window switch it cost me three pistons not using it. Trans broke hit the limiter on the gun never made it into second gear motor started huffing crank case presure. Lifted three ringlands.
Old Jan 7, 2005 | 11:13 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Anyone have any recommendations for a brand name of rpm window switch or rev limiter?
Is there one box that does both??
I am at a 75hp shot now and want to go to 100hp shot or more.
LB9GTA
Old Jan 7, 2005 | 11:49 PM
25THRSS's Avatar
For an "all in one" ignition box, I would look into the Mallory 685
Old Nov 7, 2005 | 06:25 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Same Question?
Kevin
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
billybob6110
Sep 24, 2016 09:50 AM
stalkier
Aug 21, 2015 01:54 AM
Wylecoyote08
Aug 14, 2015 08:28 AM
