Help with Nitrous Misfire
Old Apr 10, 2005 | 08:03 PM
Z RATED IROC's Avatar
Car: 89 Camaro
I need some advise from those who spray large doses of nitrous on a L98 style engine.
I am getting pretty consistent nitrous misfiring between 4,500 and 6,100 rpm. But only when I run nitrous. N/A it runs like a dream.
Air fuel ratios don't seem to be the issue because it happens anywhere between 11.2 and 12.5.
I did have one run where it hit 13.2 and it didn't misfire though.
Originally the tach needle would jump when the misfire would happen. A loose connection on the tach signal wire was fixed so now the tach is fine. However the misfire still happens.
When I pull the plugs they look fine.
Here are some details:
Miniram intake
F.A.S.T engine management
11.2 compression
AFR 195s
2 different sets of autolite plugs (1 step colder) .035 gap
Taylor 10.4 mm wires (New)
MSD 6AL
Accell cap, rotor & remote coil.
Any suggestions would be greatly appreciated...
Old Apr 10, 2005 | 08:55 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
How much are nitrous are you using?
Old Apr 10, 2005 | 09:04 PM
Car: 89 Camaro
I am using a 150 shot.
db057
Jan 10, 2020 08:55 PM
NZKnight
Oct 15, 2015 02:47 PM
camarohelp
Sep 22, 2015 03:19 PM
anesthes
Sep 18, 2015 12:34 PM
Jk_Under
Sep 8, 2015 08:13 AM
