305 Injector size and Nitrous
Old May 25, 2005 | 07:42 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I have a '91 GTA with a 305tpi and dry nitrous.
I have the stock 19lb injectors and I have gone through 2 bottles of nitrous at 75hp with no problems.....yet.
I would like to bump up the nitrous this summer to a 100hp shot.
I have been told that I am maxxing out the 19lb ers.
Should I get a set of used lt1 24lb injectors instead?
I have a afpr now, also.
LB9GTA
Old May 25, 2005 | 08:43 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
He He....i would if i were you.... later pal, GTA.....
Old May 25, 2005 | 10:08 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
You're "heads" ahead of me anyway!
Old May 25, 2005 | 10:17 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Funny...... later.GTA
Old May 25, 2005 | 11:36 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
if you do go to a 24lb injector you will have to tune the system for the increase in fuel. i did it with mine. i also ran a 24lb inj with a dry and a wet kit. i had a hell of a time getting it set right. i prob had 20-30 dyno pulls on it trying to tune for both dry and wet kits.
Old May 26, 2005 | 11:31 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Has anyone done this before on a 305?
Does the idle go crappy or the WOT is not as good?
Do I lose my driveabilty??
Old May 27, 2005 | 04:10 AM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
too much injector. you dont need to change them to a 24lb. if you are worried, then get a stock 22lb, but dont be surprised when it dosnt work that well.
Old May 28, 2005 | 12:28 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
So the driveability goes then?
Old Jun 1, 2005 | 01:32 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Honestly, I think you'll be perfectly fine running a 100shot on the stock 19#'s. Should provide enough fuel.
When going to a 100shot though, you may want to swap in plugs that are one step colder (AC Delco R44TS) and run some 93 octane.
I currently have a 75shot setup on my LB9. Wish I could feel the power a bit more though. I can't really feel when it kicks in, but I can sure notice my MPH higher at the end of a nice straightaway that I always test speed on. Used to get to about 85mph on the street which is just under a 1/4 (makes sense, my trap for 1/4 was 88). With the 75shot, I was able to hit roughly 92mph, which is roughly a 7mph gain, which means that nitrous must be giving me about another 75hp
I'm running stock (leaking) 19# injectors for now but will be swapping to 24# soon. However, I'll be running an LT1 intake and LT1 heads (flowed at 221/179 @ .500") with roughly a 10.2:1 CR, CC304 cam, and 1 3/4" headers. I'll also have an adjustable fuel pressure regulator and can burn my own chips.
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
gta90
Sep 15, 2015 04:00 PM
bamaboy0323
Sep 3, 2015 06:07 AM
knight72
Aug 10, 2015 09:32 PM
