Vortec 88-92 TPI S-Trim blower question
Old May 28, 2005 | 07:50 AM
defpony's Avatar
Car: 85 iroc z28
Part Number:
4GF218-068SQ 88-92 5.0 & 5.7 TPI F-Body w/V-2 SQ S-Trim, Polished
It says its for an 88-92
Will it work for an 85? What problems will i encounter?
Old May 28, 2005 | 09:16 AM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
The main issue is that kit, and most all other f-body tpi supercharger kits, are designed around the serpentine accesory setup that is found on the 88-92 f-bodies. Yours, assuming it's still stock, has a v-belt setup. There are a couple of ways to get around this...do a search, it's been hashed out on here numerous times.
Old May 29, 2005 | 05:06 AM
defpony's Avatar
Car: 85 iroc z28
ok ive read up on it and see what u mean.
When the time come sill probably try find some second-hand 88+ pulleys or some aftermarket ones failing that.
And ill get the shop to install it all at the sametime as the blower, wud be a lot easier.
is that the only thing i gotta worry about?
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
toronto formula
Nov 10, 2015 06:17 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
