couple of wiring question....
Old May 30, 2005 | 10:19 AM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I have the digi 6+ ignition box and the digi window switch....
Im trying to wire all this up to run with my NX kit and Im lost....
I have the WOT switch and FPSS if that has to do with any of the wiring.....
Here where I am so far.....I mounted my window switch inside the car and ran red to power, black to ground, tied off the grey wire(not used) and ran the yellow and white wire into the engine bay...where is the yellow and white wire going to tie into?
I still have yet to mount or wire the 6+ box....
Old May 30, 2005 | 02:58 PM
Ok, bottle opener is wired and working, bottle heater is wired and working. I have a purge wire coming off the purge switch and routed to wire my Arming switch and I have a wire routed from my WOT switch to where my arming switch will be.
Does any other wire except for power and ground go to the arming switch? So I can be done with that part of the wiring?
Then all the wiring is done under the hood for the Digi window switch and Digi 6+ box.
Ok then, I wired the pruge to the arming switch like it says in the directions....and then I have a wire also coming from my arming switch to the engine bay so I can wire that into where ever it goes...
atleast all the cockpit wiring is done....
Now if I can jst figure out the digi 6+ and window switch wires...oh and the wires on the relay ...I think the go to the window and digi somehow...
specialized
Jun 18, 2022 09:26 AM
Cleotiz
Jan 6, 2018 08:56 PM
Thornburg
Aug 30, 2015 08:05 AM
TheExaminer
Aug 19, 2015 10:07 PM
