Hood Clearance
Car: 1988 Camaro
Engine: 5.0
Hood Clearance
Whats the most powerful supercharger that I could fit on a V8 88 Camaro and have enough hood clearance for the stock hood?? Can anyone help please???
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you used a stock bottom end you could just remove the rad entirely. It wouldn't live long enough to get hot anyway.
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Originally posted by 83 Crossfire TA
Heh, we had a guy that was trying to run an F1 on a stock/stockish 4.3L S10 pickup…
and what happened?
it was just generally unhappy... ended up putting a pulley the size of a PS pump pulley on it to slow it way down, but it was still trying to grind the tires into the pavement at idle when it wasn't moving. It was actually spinning the tires at idle with a minispare on the back...
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
