Mini-Ram 383 & nitrois ports
Old Jun 11, 2005 | 01:34 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Hi,
Getting ready to install externals on new 383 already Dynoed
at Hp502/Torque507 Injected TB and Dyno headers.
Will be using Mini-Ram SVO#30 and 58 TB.
On down the line would like to be able to run Nitros if I want to.
Before installing Ram would like to drill and tap holes into runners
and then plug them for future use so wouldn't have to remove
intake on down the line.
Pain in the rear the way its setup
What size hole-thread size and placement would be best and has
anyone been there done that?
Any help or suggestions appreciated. New to NOS but think
would rather go with port setup with wet kit.
Tried to post pics of new motor on stand but file attachment to
big. Will try to change camera setting.
Later
jaykar
Old Jun 13, 2005 | 02:44 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I wanna say they're 1/4" NPT for the nozzles. Where you place them is up to you. Just remember you have to fit injectors, solenoids, valve covers, fuel rails, and everthing else.
Drill now and plug, that way you don't have to do it later. But you have a Mini ram, so it's not like it's real hard to pull that intake anyway.
Old Jun 13, 2005 | 03:39 PM
jaykar's Avatar
Nitros Ports MiniRam
Hi,
Thanks for reply.
Found a couple setup pics on another site and see what you
mean about the solenoids and hardware placement with the
port setup
May need to get hold of NOS and see what they recommend
as to this manifold and setup.
The setups I looked at were LT1 &4 but basically the same
as to plumbing. Maybe think about a wet plate setup but hate
putting a restriction in front of the TB. If I drill, tap and plug
going to have mock up on the engine stand as to getting the
nossles angled correctly for clearance and such.
Getting ichy to drop this thing in and if problems can always
pull intake if I go that route.
Later
jaykar
Old Jun 13, 2005 | 04:03 PM
BlownBird's Avatar
1/8" npt on all the fogger setup's I have ever seen.
Old Jun 13, 2005 | 04:28 PM
jaykar's Avatar
Nitrous MiniRam
Hi,
Thanks for reply.
May see if I can get just one wet noozle to use as mockup
as to angle of hole placement.
Can't afford the system right now as have pretty much maxed
out this projects budget. Won't talk about the other halfs opinion
Also just got done looking at a NOS Cold Fusion kit for a LTI
that could apply possibly
Setup to 200HP.
Really not looking at more than that, as Show and some Saturday
nite activity. Already sitting on 502 all motor.
May find friend with CNC Machine and do it rite when time comes
as to perfect angles and alignment. Have nice drill press but not
all the tooling.
Kit advice also appreciated
jaykar
Old Jun 13, 2005 | 08:48 PM
406 S10 Man's Avatar
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
Most of the standard port kits come with 1/16 npt nozzles, the big ones are 1/8. You'll probably have to contact one of the nitrous companies for a 1/16 tap.
Old Jun 13, 2005 | 09:34 PM
jaykar's Avatar
Nitrous
Have all the taps.
Just wondering how Busy things are going to get behind
#3 and #4 cyl with all the hardware.
Showcar and like things nice and neat, althought running
2 1/2 Harwood lid so that opens room up top for solenoids
and hardware
Running close to 11 to 1 but cam setup fine on static comp
for pump gas.
But if could go back, would have set motor up for turbo or
blower.
Going to go Nitrous for sure but just have to figure out the best,
safest and most practible way to do it with 200 max setup.
Later
jaykar
Old Jun 14, 2005 | 07:42 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Whoops. Sorry, yall are right. 1/8" NPT.
Reid Fleming
Oct 10, 2015 09:56 PM
LT1Formula
Oct 8, 2015 08:34 PM
