beginning a TT 305 build, cam advice
Old Jun 13, 2005 | 05:40 PM
comatose 88 WS6's Avatar
Car: Chevrolegs
im about to get an 86 iroc with a 305. im going to bore the motor over .030, bolt up afr180s, and a sr. the kit would be from bbc designs(i think thats right). im not sure what came i should use for it though. i may also go upto a 355 with a hsr and afr 195s.
Old Jun 14, 2005 | 07:52 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Gee, I wonder which one I would build? The 305 or the 355. There's a tough one.
A TT motor is going to be more of a PITA and more expensive.
Old Jun 14, 2005 | 07:17 PM
Car: Chevrolegs
not necessarily, if youve seen the website youd know the setups are about the same price as a vortech s/c. hmm, turbos or a s/c......people always seem to offer only sarcasm and no help these days...
Old Jun 14, 2005 | 07:55 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
yes, the 305 is not that bad, just ignorant people. now the 350 may be better choice due to the availiability and price of pistions in the comp. and style you may want. the only other benifit of the 350 is valve shrouding on a "stock" 305
now the 305 will have better flame control due to the smaller bore (I know there is plenty of info on this around here)
your cam choice well, comp cams shows a mechanical roller cam 300br-14 "for turbo sbc" this has a valve lift of .575/.575 114 lobe sep. 255/262 dur. @.050" this would be better for a 350 or larger and they claim it is a street/strip cam
they have so many more choices if you want to run hyd. lifters, hyd. roller ect. but, this one seems pretty good has a range of 3000-6000 rpm and when I buy my next cam it will be a mech roller.
jhawkeye
May 25, 2022 06:33 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Reborn756
Sep 4, 2015 03:42 AM
makaveli09
Aug 12, 2015 09:07 PM
