View Poll Results: 350 or 400 build
build the 400 even though the cost of parts is very $$$
50.00%
build a 350 for much less and still go forged
50.00%
Voters: 4. You may not vote on this poll
stupid matco tools what now?
Old Jun 16, 2005 | 08:03 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
ok, long story short I go to put on my new sbc 400 balancer everything is going smooth and all of a sudden the installer gets real loose and falls out in my hand.... I look and see the end the threads into the crank litterally pulled apart! not twisted but, flat out pulled apart looked like it shattered the threaded part is now stuck in the crank like a broke off bolt. and since it is hardened I am now SOL
I guess I get to pull the eng out now.
since I will be pulling the eng. what would you guys do? replace the crank and rods with a much better or would you ditch the pricy 400 and go for a 350 with forged internals as well?
keep in mind this eng, has afr 195 heads HSR and has a procharger f-1
Old Jun 16, 2005 | 08:47 PM
Treys_IROC's Avatar
Car: '89 Camaro
Engine: Blown 5.7L TPI
that sucks man, i feel for ya good luck with whatever route you take, i'm a penny pincher so the 350 gets my vote.
Old Jun 16, 2005 | 09:04 PM
head's Avatar
Car: 1984 MSE #52
Transmission: TH700
Rebuild the 400 ; with forged internals !!!!
Old Jun 16, 2005 | 09:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you were patient, you could still drill it out with a left-handed cobalt bit.
Old Jun 16, 2005 | 09:56 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Fix it. Just like in a good **** flic, there's always something harder (for drilling, like in a **** flic). Get a good bit and go to town. One helicoil later and you'll be good to go.
Old Jun 17, 2005 | 01:23 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Its not the tool my snap on one did the same thing. It almost wrecked my crank. Serously the only way I have been able to put those on was with the crank bolt. I was able to get it out with an easy out and a coalbalt drill bit.
Old Jun 17, 2005 | 06:50 PM
Engine: ls1, LB9
you guys are right but, I was very pissed off and have been looking for a reason to build a tough short block, I have some cutting bits that I may give a whirl since I won't be out anything. it was an upsetting moment when the thing broke about a belt rib from where it needed to be.
92projectcamaro
Dec 8, 2015 12:25 AM
Reid Fleming
Oct 10, 2015 09:56 PM
djmarch
Oct 2, 2015 10:41 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
