Carbed And Blown...fuel System Advice
Old Jun 23, 2005 | 12:25 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I currently have a 355 with a SR and nice shot of gas(around 500 rwhp) I am switching up and going with a turbo/carb setup and aiming for about 650 rwhp.
I have a couple questions on the fuel system. First will the stock lines support this? Also, now I have a walbro 255 intank pump thats been doing well with my current setup, but i dont believe it will support my new carbs volume needs.
What are my options? I would like to discuss sumping/cells also, but would like to stay with a stock like setup as my friend has problems with his sumped stock tank starving for fuel sometimes.
TIA
Chris
Old Jun 23, 2005 | 06:37 PM
blown3rdgen's Avatar
My low boost set up was holley "black" with a mallory #4309 regulator.
Today actually I just recieved my new and improved set up. Aeromotive A1000 pump with 13204 regulator. My lines are -10 to the pump then -08 and 1/2 hard line to front; same on the return. RCI made me a custom fuel cell for like $250 I think (3yrs ago can't remember exactly). Just give them the diminsions and crude drawing.
Old Jun 24, 2005 | 01:57 AM
83 Crossfire TA's Avatar
HP requires fuel volume. If the pump can move enough hp for what you’re doing at 35psi it will work at 7psi (not true of compressors and compressible gasses, but fuel is basically non compressible…).
The only thing that you’ll need is a bypass regulator that can flow enough and be set down low enough to work. The aeromotive 13204 is probably one of the better choices. It’s also quite likely that you’ll need a bigger return to get this to work right.
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
theurge
Aug 21, 2015 12:46 PM
stalkier
Aug 21, 2015 01:54 AM
