Nitrous...Can It Handle It?
Old Jun 23, 2005 | 07:15 PM
klumb15's Avatar
i ripped my car all apart this winter, built up the drivetrain and motor...i don't know what the motor will put out, but it has vette alum heads, .536/.543 224/230 cam and HSR intake...if anybody wants to throw an HP estimate out there that would be great....but as far as the bottom end, i had the crank ground .010, then all new cam/crank bearings, and new pistons...and it is a 2 bolt main block...i'm guessing about 350-400max...you think the motor can handle a shot of nitrous on top of that, and if so, how much??
Old Jun 24, 2005 | 02:07 AM
83 Crossfire TA's Avatar
The cam and the intake are going to want more rpm then the heads… the heads will probably try to drop dead by 5K rpm unless they’ve been worked, and then if everything else was perfect/matched you’d top out in the 360hp range at the crank.
You could throw a lot of spray on top of that.
Old Jun 24, 2005 | 11:07 AM
klumb15's Avatar
really...how much spray...
Old Jun 25, 2005 | 11:50 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
What are the pistons? Cast, hyperutectic, forged?
That and your ignition will dictate how much spray it will handle.
Old Jun 25, 2005 | 08:51 PM
klumb15's Avatar
well i would get that nitrous MSD ingnition box, then my pistosn are silvolite stock replacements...so I would say cast...
Old Jun 27, 2005 | 11:03 PM
Nitro Dave's Avatar
Engine: 94Z28
You could safely spray a 100 shot maybe a 150.Make sure your fuel system is up to par.
Dave
Old Jun 28, 2005 | 11:12 AM
klumb15's Avatar
i have a 26# injectors, and the fuel pump will prolly go out before I spray it, so I can get a bigger one....so it would be able to hold a 100 shot no problems? as far as strength and fuel supply....what should I run, wet or dry? my friend has a 150 shot dry on his LS1 camaro, with just a cam, and stock fuel system, seems to work out nice for him....and his injectors are 28#
1992Z28!
Nov 19, 2015 07:33 AM
Numbah-1
Oct 2, 2015 08:27 AM
ndndndnd
Sep 28, 2015 08:00 AM
roysatikas
Sep 22, 2015 08:15 PM
apie2546
Sep 20, 2015 01:03 PM
