nitrous question
Old Jul 5, 2005 | 04:05 PM
transam32's Avatar
nitrous question
i was thinking about buying a nitrous kit to put on my engine, do you think that a 150 shot would be too much for the engine since its a 350 with about 500hp. if not what do you think would be a safe shot to run on it?
Old Jul 6, 2005 | 08:23 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
kNEed mo IfOmaTion on MotOr.
Specifically the crank rods and pistons and rings.
Old Jul 6, 2005 | 09:01 AM
transam32's Avatar
Comp cam 12-246-3 , 490 int/ 490 ext
Seal Power hypereutectic flat top pistons and rings.
Clevite 77 main & rod bearings.
Durabound camshaft bearings.
Dynagear 3pc. dual roller timing kit.
Brass freeze plugs.
Fel-pro full gasket kit.
performance valve lifters.
Melling high flow oil pump, pickup tube and drive-rod.
Melling hardened push rods.
edelbrock RPM aluminum heads cnc ported bowel blended,10.2-1 compression, 2.02 int/1.94 exh 170 intake runners
Aluminum Roller rockers
EAGLE STEEL CRANK SHAFT
Eagle rods
ARP head bolts
ARP main bolts
Old Jul 6, 2005 | 09:14 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
um, the really important question is, can your fuel system support the engine at WOT and the nitrous shot?
Old Jul 6, 2005 | 09:20 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Brass freeze plugs.
Eagle rods
ARP head bolts
ARP main bolts
100 shot should be fine on those pistons, I don't see that combination making much more than 425 horsepower though.
Old Jul 6, 2005 | 09:21 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
1.94 exhaust valve? Interesting.
What fordging is the crankshaft, and rods?
MustangBeater20
Oct 29, 2022 09:20 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
