nitrous
Old Jul 7, 2005 | 08:20 PM
chevrunner21's Avatar
Car: 1992 trans am
Engine: 305 tpi
nitrous
how big of a shot of nitrous might i be able to put on a stock 1986 iroc camaro and what is a good reliable cheap kit with that shot?
Old Jul 8, 2005 | 11:08 PM
86MaroTPI's Avatar
Car: 1986 Camaro Z28
bump
Bump. I'd like to know also.
Old Jul 8, 2005 | 11:21 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Fast, Reliable, Cheap
Pick two you dont get all 3.
With that said, what engine / induction setup will this be going on, and what do you have for a fuel pump ?
Old Jul 9, 2005 | 01:12 AM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
i've done some research on this topic
i guess under a 100hp kit you should be fine
to be safe, get an rpm switch that kicks it on after 3k and off around 5500
along with maybe a fuel pressure safety switch
the NOS kit seems nice and the nitrous works is also nice
Old Jul 11, 2005 | 06:53 PM
Nitro Dave's Avatar
Engine: 94Z28
100 is going to be the safe spot on the stock bottom end.I suggest a NX system.
Dave
Old Jul 11, 2005 | 08:41 PM
NOSFEDGTA's Avatar
I ran my nx system on my 88 gta for 2 years when it had the stock bottom end. I ran 100 shot most of the time, and the occassional 150. I had 186k on it and still sprayed it The nx kit will be a better choice than the nos plate kit, due to distribtution issues with the plate setup. It is common for cylinders 1 and 2 to be leaner than the the others. Reason is the plate is behind the throttle body so when the nitrous enters the plenum it has a tendency to spray pat the fron 2 cylinders.
Old Jul 12, 2005 | 06:00 PM
Car: 1992 trans am
Engine: 305 tpi
nitrous
thanks alot for all the information
CarGuyDennis
137
Dec 6, 2016 11:02 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
FlyinLow89
Nov 12, 2001 02:35 AM
vortech305
Mar 30, 2001 12:21 PM
