Nitrous Carb Plate kit Q
Old Jul 12, 2005 | 07:50 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
I have a double pumper holley with a MrGasket dual feed line, on this line is a 1/8" npt fitting, can i tap off that for a nitrous fuel feed?
it's a red holley electric pump, i'd figure maybe a 125 shot
they have 1/8" to AN4 fittings, which would work for the fuel supply right?
i figured at most with a 125 shot that would make 400hp
rpm range i am aiming at it 3-5.5k range
the red pump should be enough for the motor and nitrous right?
i'm looking into the NOS super power shot kit or one of the edelbrock kits
Old Jul 13, 2005 | 09:39 AM
Nitro Dave's Avatar
Engine: 94Z28
You would be better off buying another pump and running a dedicated line fuel side for the nitrous systsem.If you go with a holley style atlleast get a blue.
The way you are looking to run it there is not enough fuel supply from that pump to supply the motor and nitrous.
Dave
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
mhatfield 14
Oct 24, 2015 07:48 AM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
overdriv
Aug 20, 2015 03:52 PM
