ok, another desk top dyno question
Old Jul 15, 2005 | 06:10 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
how do I change the supercharger data for a procharger F1. I was reading through the instructions and it does not cover all of it. it says the boost limit is where you set the max psi your motor will see at. but, when I set it at 10 it shows my eng, seeing like 32 psi not to mention the specs can't go as high as the procharger specs
help I am confused
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
