305 stealth and 100 nos ?
Old Sep 5, 2005 | 10:20 PM
coolacts's Avatar
Car: 86 transam
Transmission: t700
Hi from australia i am apparently the only one in auz with a stealth ram in a transam and i have just purchased a 100hp zex nos kit. only thing is since changing from tpi to stealth the car surges a little bit and has a small pop or backfire when decelerating no throttle . at wot the car runs smooth and fine to 6000rpm i have fuel psi at 50 and run 12 degrees. do i have to do anything else before i button the 1oo nos eg i was thinking of getting a tuner cat to see what more power i could extract when on the gas? anything else oyjer than colder plugs and reducing timing this is a stock 305 with stock 86 maf chip any tips for tuning with this setup with the tunercat? any help would be apprecited as i do not want to blow on my first pass !!! cheers
Old Sep 7, 2005 | 06:08 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
back the timeing back off to stock . That may help with the backfireing. You do know you have to retard it about 2 degrees for every 50 hp of NOSSSSSS so for a 100 shot .... take 4 degrees out of'r mate . This all for while under the influence of giggly gas . When running without it ....I'd just back the timeing off to more stockish. Might help a bit.
1992 Trans Am
May 10, 2023 07:19 PM
9192camaro
16
Feb 3, 2019 12:21 AM
69 Six Pack
Oct 5, 2015 07:51 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
L98GTA87
Aug 11, 2015 06:55 PM
