How to beat a low 13 second stang
Old Nov 3, 2005 | 08:13 PM
maroguy1's Avatar
Car: 85 iroc & 81 sc
Engine: 357 tpi 350 4bbl
Transmission: 700r4/ richmond 4speed
Axle/Gears: 9 bolt 3.45/3.42 8.5"
Over winter I need to get my car to run in the 12's so I was thinking a s trim. I have never ran my 85 and I think it will run high 13's as is but I am not sure. I am running stock suspension and unported vortec heads. Do you think I am on the rite track with this before I spend the big dollars?? Details of car in signature.
Old Nov 4, 2005 | 08:52 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
$400 into a 150 shot and it's done. Or you could spend $4,000 in a blower set up.
Old Nov 4, 2005 | 08:02 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Depending on the cam you should be able to run 12's with a stealthram and traction. 150 shot and your in the high 11's...
Old Nov 5, 2005 | 08:04 AM
maroguy1's Avatar
It has a pretty mild cam.
Old Nov 6, 2005 | 04:14 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
Who do you want to run? I'll run him for you .
I see you are local, I haven't been out and about much lately so we haven't met.
Kory
Old Nov 6, 2005 | 08:31 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
I have the exact engine setup in my 92. N/A my best time was a 14.39 at 96.7mph. I had an open 2.73 rear and stock tranny though. I turboed it to get into the 12's
Old Nov 6, 2005 | 09:28 PM
maroguy1's Avatar
He was down at great lakes and ran a 13.3 all day long. My trans is built though with a 2500 stall and with my 3.45 rear geared posi that should get me into the mid 13's If you were runnin low 14's with an open lame gear and stock trans. I was looking into the hurst shifter setup also. HOw do you like yours?? Thanks
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Damon
Sep 26, 2015 04:29 PM
