Measuring A/R and Wastegate settings
Old Nov 11, 2005 | 07:38 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Exhaust A/R:
How is the A/R calculated for divided flange exhaust housings (T4 and bigger)? Normally you just measure the inlet area and divide that by the radius from the wheel center to the center of the place where the area was measured.
I ask this because I have a Holset turbine that is a 19 cm^2 housing that is divided. I can measure the area at the flange and measure the radius. This area measurement includes the area that is steel in the center (the divider).
Should I include the steel divider in the area calculation or measure just the two exhaust holes and calculate the area of the two holes to do the A/R?
Aftermarket wastegates:
How does a manufacturer rate an external wastegate? If a "6psi" spring is in the wastegate, would the gate start to open at 6psi or be fully open at 6psi?
Thanks,
J
Old Nov 13, 2005 | 04:06 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I think you get what is called "creep" it starts toopen a bit before the actual 6 psi
Old Nov 13, 2005 | 10:40 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Are you saying that they are rated at fully open? A "6psi" spring would mean that the actuator is fully open at "6psi". Correct?
Thanks,
J
Old Nov 14, 2005 | 02:15 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
I think that is correct....I am a little new to all this myself.
Old Nov 14, 2005 | 11:43 PM
junkcltr's Avatar
Engine: 3xx ci tubo
I checked the A/R thing. It really is the Area of the hole.
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
GTAman
Mar 15, 2019 11:40 AM
deracer
Apr 11, 2016 12:04 AM
anesthes
42
Oct 24, 2015 07:30 PM
