spraying a stock L98
Old Nov 15, 2005 | 01:04 PM
3rdgen92maro's Avatar
Car: 1995 Firebird Formula
Transmission: Th350/4k stall
Axle/Gears: 10 bolt with 3.42s
i have a 1991 z28 with 78K. i want to put some spray on it but i not sure how big i should 75-150 shot. will a stock l98 hold a 150 shot or should i just go with a 75 or 100. any advice will help.
thanks
Old Nov 15, 2005 | 02:47 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Old Nov 15, 2005 | 02:50 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
https://www.thirdgen.org/techbb2/sea...der=descending
Old Nov 15, 2005 | 08:42 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
It will take a 150 shot. As suggested above do your research. The 150 shot is safe assuming all the necessary precautions/systems are in place (adequate fuel system, ignition system, etc etc.).
Enjoy
-Schultzy
Old Nov 17, 2005 | 04:52 PM
Raiden's Avatar
I hate it when every one says...search! The boards are to help our fellow brotha's out! Yea, you should do a search before asking, but let the bro ask a question!
To answer your question.......Search! The main thing you have to be concerned about is detonation. Follow the instructions with the nitrous kit, They always say, MAKE SURE you have a good tune! I would not put any more than a 150 shot on a stock engine. And make sure you have 6deg or less initial timing.
Old Nov 18, 2005 | 01:31 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Yeah I think the rule of thumb is for every 50 hp shot you run ...retard the timeing 2 deg. Also I would get every safety device you can for it ....i.e window switch , etc . all the neat guages and whatnot.
Happy spraying
lt500r55
Sep 1, 2021 01:30 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
