NOS 5151 wiring
Old Nov 25, 2005 | 12:12 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
NOS 5151 wiring
I bought a used nitrous kit with everything but the wiring to the relay. Now I have the manual with the wiring diagram but what wires go to what prongs on the relay. Is there a harness that plugs into the relay? They refer to something like a harness that plugs into the relay in the instructions but there is no PN for it. Maybe there is no harness for the relay, I am not sure. I hope someone on here can straiten this all out for me.
Kevin
Old Nov 30, 2005 | 06:02 PM
Engine: L98 350 TPI
Can anyone help with this?
Kevin
Old Nov 30, 2005 | 06:15 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
there is a harness, but you don't nessesarily need it. You can use regular female spade connectors. Or you can go to your local parts store and get the harness. Just tell them you need the harness for a 30 amp cooling fan relay. It's the same thing. Radioshack may have it as well.
Eric
Old Nov 30, 2005 | 09:50 PM
Engine: L98 350 TPI
sweet. But what wires go to what prong on the relay. It shows where they all go to in the manual, but it does not show the specific order on the relay itself.
Kevin
Old Dec 1, 2005 | 01:48 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
the relay itself should have numbers on it near the prongs. There should be 30,85,86,87,and 87a.
85 and 86 are the control side. Connect 85 to your switch circuit, connect 86 to ground. 30 should goes to fused battery power, and 87 goes to your solenoid. nothing goes to 87a.
Eric
Old Dec 1, 2005 | 04:25 PM
Engine: L98 350 TPI
Thank you very much Eric!
Kevin
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
fasteddi
Sep 2, 2015 10:29 AM
Bryan F
Aug 27, 2015 07:28 AM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
