1980 Turbo Trans AM parts swap
Old Dec 4, 2005 | 01:48 AM
Rage2004's Avatar
Car: 1986 Trans Am Barris Custom from the short lived TV show Force 3
Engine: 305 4 barrel
Transmission: 4 speed automatic
I know that the old turbo Trans AM is not the motor that one would use for a swap. But, would the turbo and manifolds work on a 305 HO motor? I know it wont just bolt on, I was wondering if the turbo could be used and the manifolds could be modified to fit on. What would be needed to make this work besides $$$?
Thanks guys,,,
Old Dec 4, 2005 | 12:35 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
not claiming to be an expert about this, but i'm gonna say no.
that was a pontiac motor, so the exhaust is completely different
not to mention that is a way outdate design, and really wasn't good.
then again it was used on one of ponitacs worst motors lol
Old Dec 4, 2005 | 07:41 PM
1981TTA's Avatar
Car: 81 Turbo Trans Am
Engine: 301 T
Transmission: 200-4R
Neither the exhaust or intake manifolds will work on a Chevy engine without MAJOR modifications. It would be faster, cheaper and less frustrating to make these from "scratch" or buy from someone who makes turbo 3rd gen parts.
The turbo itself was a little undersized for the 301 motor. Not unlike the TPI manifold for Chevy, the Pontiac 301 turbo was set up to perform for low RPM operation (below 4500). If you're setting up your engine for this type of operation, the 301 turbo might be reasonable for what you want to do. It all depends (like so many things) on your particular combination and what it's designed to do......
Old Dec 9, 2005 | 12:52 AM
IROC-Turbo's Avatar
I have one mounted on a 350 in a 89 camaro.What ya need to know??Pm Me and ill tell you all about it and show you how it looks and works!!
bigben85
Sep 13, 2015 10:12 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
rh76camaro
Exterior Parts for Sale
Aug 6, 2015 08:57 AM
