where to get "turbo" hose/band clamps??
Old Dec 8, 2005 | 01:50 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
im running a 4" mandrel bent tube for my cai when i relocate my battery. i want a connector like the ones in the pic to connect it to my throttle body. where can i find this type of connector for sale??
Old Dec 8, 2005 | 10:31 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I purchased all of my connectors and clamps (like those)at www.atpturbo.com. You have a choice of color there.
Old Dec 8, 2005 | 12:01 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
cool, are there any other places you can get them cheap? im also i guess looking for one that goes from an oval to my 4" round piping.
Old Dec 8, 2005 | 04:06 PM
JBert's Avatar
Car: Looking
I believe they are called T-Bolt clamps? Summit has them i think, i know garrett turbo carries them.
Old Dec 8, 2005 | 04:22 PM
junkcltr's Avatar
Engine: 3xx ci tubo
The stock TPI & LT1 throttle body accept a 4" silicone coupler. As for a 4" oval to 4" round coupler, I have never seen a molded one. You wight get away with a regular 4" coupler, or you may not. I never tried it. I use a CAI that is oval just the like the picture that was posted and a 4" silicone fits the TB and the oval pipe perfectly. Yes, they are called T-bolt clamps. and summit is expensive.
Old Dec 8, 2005 | 09:46 PM
92Z's Avatar
92Z
http://www.mcmaster.com/
under hose and tube clamps
page 216
Old Dec 8, 2005 | 11:38 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
so i should get a 4" siliconn coupler and then what size t bolt clamps?? will they be different sizes?
Old Dec 9, 2005 | 08:07 AM
BlownBird's Avatar
Make sure you get the 4.25" t-bolt clamps, the 4" won't get large enough.
DonB.
Old Dec 9, 2005 | 10:05 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Napa sells them, I purchsed mine there.
Old Dec 9, 2005 | 10:17 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
thanks for the help all! i konw everything i need but at atpturbo the silicone coupler are only 3" long. id like something a little longer...any place else that sells the silicone couplers?
Old Dec 9, 2005 | 03:53 PM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
http://stores.channeladvisor.com/ver...sports/Clamps/
I bought some clamps and silicone from these guys. No complaints. They'll sell you a 1' long piece if you want.
Old Dec 9, 2005 | 09:24 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
nice ill check into them too.
does anyone know for sure if the regular 4" coupler will work on the oval t.b. and the round 4" CAI tube??
Old Dec 10, 2005 | 09:29 AM
BlownBird's Avatar
a 4" round connector will fit the throttlebody perfectly, and transition to round nicely.
Inwo's Avatar
Engine: 2.0 turbo
Transmission: m5
Silicone is pretty flexible. Make sure that your TB is the right size around and has a lip. The place I directed you to has a bunch of different sized reducers if you need also.
Old Dec 10, 2005 | 11:14 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
my TB is a 58mm if that makes any difference, to get the stock boot on i had to cut the sides and use some vasoline on the tb...
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
no green
Jan 9, 2016 09:22 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
83 Crossfire TA
Sep 18, 2015 12:01 PM
Doobie52
Sep 11, 2015 06:19 PM
