454 HO superchager?
Car: too many
Engine: SBC
Transmission: AUTOs and a 5 speed :D
Axle/Gears: you name it
454 HO superchager?
I have been looking for a long time at putting a 454 HO crate in my 82 camaro
I know the compression is 8.75 to 1 for that crate
how much boost can be run with a small procharger or roots blower?
and does the max (6000) rpm of the engine change with the addition of a supercharger?
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
put a more blower friendly cam in that 454 HO and 600hp is like falling off a log.
max rpm is gonna be the same unless you change the cam and valve springs(which I agree, you should do) - under boost, cast pistons, I don't think I'd look for over 6k...
- also, even if you don't change the cam, I'd look into better valve springs for the blower.
well then cam and better valve springs if you're gonna boost it.
forged makes a big difference...you can throw much more at it! - Change the springs to suit the blower, I'd change the cam too and pick up the hp. You're there, you're spending most of the money, spend the extra and put a good cam and springs in it. Roller rockers wouldn't hurt you none either...
Mongoose462ci
Sep 16, 2015 11:46 PM
3rd, 454, 454ho, blower, cam, camaro, generation, ho, pistons, putting, spring, supercharged, supercharger, superchargers, valve
