Procharger Surge hose
Old Mar 13, 2006 | 08:30 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
how did you guys route your surge hose on your procharger? i cant find a decent way to route it without it hitting the header.
Old Mar 13, 2006 | 08:57 AM
KS91Z28's Avatar
Don't route it back to the inlet at all. The only reason you would need to recirculate the bypass air, would be if you were drawing through your MAF. Since you're not, just vent the bypass to atmosphere, and cap off the hole on the inlet side where the bypass hose is supposed to hook up.
Old Mar 13, 2006 | 09:31 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
i was thinking about that, any ideas what to use to filter the air inlet and the surge outlet?
Old Mar 13, 2006 | 10:36 AM
KS91Z28's Avatar
On mine, I just capped off the bung on the inlet elbow. On the surge outlet, the air will always be blowing out, not sucking in, but I put a filter on mine just to muffle the surge valve noise. I used K&N part # RU-0160 (ATI part# AF057I-4).
Old Mar 13, 2006 | 05:39 PM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
I routed mine just like in the procharger instructions and zip tied it as close to the power steering pump as possible and put some heat shield around the hose just in case. It gave about 1.5" of clearance and never burned through.
Old Mar 14, 2006 | 01:34 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
You find that made a real difference putting that filter on there? Thinking of doing that to mine or using the hose.
Old Mar 14, 2006 | 10:29 AM
KS91Z28's Avatar
It seemed to do a pretty good job of muffling it for me. I just hated the idea of recirculating that air. All it does is gets hotter and hotter as it recirculates. I'm all for eliminating heat any way I can.
Old Mar 14, 2006 | 11:36 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
what did you cap off the air inlet bung with?
Old Mar 14, 2006 | 12:54 PM
KS91Z28's Avatar
I had a plastic/rubber cap from a new torque converter that was laying around the shop that just happened to be an exact fit.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
sleprock
Sep 24, 2015 04:33 PM
banksGTA
Sep 13, 2015 11:56 AM
