tach signal location for window switch on tpi
Old Mar 14, 2006 | 01:01 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
as title says, i want to hook my nitrous kit up to my 91 and i was wondering if the tach signal is just off the coil or if its a seperate wire of the computer? and would anyone happen to have pictures to which wire it is? thanks for the help
Old Mar 19, 2006 | 01:53 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
I'm about 90% sure that either white wire off the ignition coil is what you want (I would use the one that does not go back into the distributor). Don't be fooled by the two two wire connectors, as it is still your standard ignition coil with a constant 12V and triggered by grounding the negative side.
Old Mar 19, 2006 | 05:08 PM
Car: 91 z28
yeah i got it figured out thanks! that digital window switch is killer, when the car is running it works like a tach!
Old Mar 19, 2006 | 11:01 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
So which one was it?
I couldn't get mine to work, either.
1992 Trans Am
May 10, 2023 07:19 PM
Wylecoyote08
Aug 14, 2015 08:28 AM
Sanjay
Aug 12, 2015 03:41 PM
Fronzizzle
Aug 9, 2015 01:15 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
