Booster fuel pump wiring?
Old Mar 27, 2006 | 10:39 PM
Raven90IROC's Avatar
Car: 1990 Camaro IROC-T
Engine: L98 Turbo (GT40)
Transmission: THO400
Axle/Gears: Forged axles, 3.23 rear
Im just about to install my Bosche 044 booster pump in line with my stock intank, just after the fuel filter.
My question is can i just run wiring off the power to the stock pump so that the new pump is just powered at the same time as the stock one?
Old Mar 28, 2006 | 09:47 AM
Damon's Avatar
I would think that's how you'd do it unless you only wanted it to turn on with nitrous, or at a certain boost level or under some other conditions. Make sure your electical supply to the pumps is up to the task of supplying them both at the same time with engough juice to prevent voltage drop (not sure if the stock wiring is).
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
