MAF within procharger path?
Old Sep 12, 2000 | 01:47 AM
Transformer's Avatar
Will the MAF hold up in the path of the forced air from the blower? Has anyone had any MAF problems with this set up.
88GTA 5.7(under construction) ATI Procharger,58mmTB,ported plenum,SLP runners,Edelbrock HI-FLO base.ported heads,1.5RR,210/220/480 compcam,AFPR,SLP1 3/4 headers,3.70 gears,Eibach drag launch,Lakewood LCA`s, Nitto drag radials.
Old Sep 12, 2000 | 08:04 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
The MAF is placed on the inlet side of the SC, not the compressed side.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 113 mph (50-hp nitrous).
http://www.ozemail.com/au/jca69/mods/williesz/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old Sep 12, 2000 | 01:58 PM
89ProchargedROC's Avatar
I have the 12psi kit and have the screens removed and had it ported. No problems so far. BTW, the MAF goes right above the battery in the intake tubing.
Old Sep 12, 2000 | 04:11 PM
maniacc's Avatar
If i'm not mistaken....from what i've seen and read on the ATI systems the MAF is in the pressure side.....after the aftercooler and before the TB....
I'll let you know as soon as they ship me my D1sc....it's was supposed to be here on friday!!!
later maniac,
MÅN¡ÅÇ ©
88 IROC 5.7L,edelbrock TES,random tech cat,borla exhaust,chip,sfc,accel wires,airfoil,k&n's,ETC..
http://maniac.megamania.com
Old Sep 13, 2000 | 06:27 AM
PROCHARGED89Z's Avatar
Mass air meter on the ATI system goes between the last 2 tubes before the manifold,The rubber fitting is extra long here,split it down the middle,put one on each end with a little gasketch and hose clamps and you are golden. Remove the screens if you havent done so yet.
Mark_ZZ3
May 24, 2018 01:02 PM
racereese
Oct 3, 2015 03:46 PM
sleprock
Oct 1, 2015 09:39 AM
-=Z28=-
Sep 24, 2015 10:21 AM
