Can my car run with a supercharger?
Old Sep 11, 2000 | 08:34 PM
Humvee's Avatar
I am curious to see if my car can run with a supercharger successfully. If it can, how much boost can be applied? Do I have to rebuild the engine to handle the supercharger? Or is it almost to the point of slapping it on, making few adjustments and you're set? I am getting tired of getting kicked around by normal cars... (Yes, normal cars...) Basically, I want to know is what has to be done to make my car be able to handle a SC. I want to mod my car accordingly. Thanks!
BTW, my car has 75,000 miles... totally stock... 305 engine with automatic transmission. It's a convertible, if that changes anything...
1989 IROC-Z Convertible
305 TPI automatic
White with black top
Mods:
None to date... Working on it!!!
My webpage: http://mindspring.com/~humvee
Old Sep 12, 2000 | 12:34 PM
Humvee's Avatar
There's got to be someone that has done this!
305 TPI automatic
Mods:
Old Sep 13, 2000 | 10:24 AM
Doug E's Avatar
Humvee,
The virtue of adding a supercharger to your engine will be an immediate, substantial gain in horsepower and torque. More air simply means more power. Unfortunately, this also adds a lot of stress to the working components of the engine.
If you were to rebuild the engine specifically with a supercharger in mind, use as many high quality components as possible, and get the work proffesionally done. Decreasing compression ratios to about 8.5 - 1 will enhance the supercharging effect. This also brings in the computer problem with the TPI system, so a new chip will likely have to be burned.
Hope this helps,
Doug E
Old Sep 13, 2000 | 10:27 AM
Conv389drv's Avatar
Well, since your engine is TPI, I think you'll have to go with a centrifugal supercharger instead of a roots type. The centrifugal kind might be more difficult to install and tune, but I don't think you'd have to rebuild the engine or anything, just so long as you keep the boost low (around 6-8 lbs maybe). This engine has something like 9:1 compression, right? You might have to use bigger injectors, but that's probably about it. I have heard of guys who supercharged their 305 TPIs, but I don't know if there are any of 'em around here on this board.
'62 Bonneville convertible
389 w/ 3-speed auto
"Ignorance is strength"
--1984
Old Sep 13, 2000 | 12:40 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Look no further. Check my sig!! Then if you have any questions, please e-mail me.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://www.ozemail.com/au/jca69/mods/williesz/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old Sep 13, 2000 | 01:54 PM
Conv389drv's Avatar
Ah yes, Willie, you're the guy I had in mind. Running 12s with a 305 that's a daily driver and emissions legal, that impresses the hell outta me!
389 w/ 3-speed auto
--1984
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
