Vortech + Nitrous..... any thoughts?
Old Sep 17, 2000 | 07:29 PM
87SC/SS's Avatar
Car: 92,94 Camaro, 95 Bird, 12 Silverado
Engine: 5.7, 3.4, 5.3
Transmission: 700R4, T5, 6L80E
Axle/Gears: 3.70, 3.42
I'm building up my 350 and converting it to TPI. I'm gonna be using speed pro lightweight fully machined hypereutectic pistons. The CR w/o the blower is 9.6:1, the heads are WP Sportsman II's (cast iron), Crane Compucam 2040 flat tappet, hedders, stock rods, stock crank, 4-bolt mains. I'm toying with combining a vortech s/c with nitrous. Sort of turning the nitrous into a intercooling effect for the s/c. I have two questions.
1. Will the engine handle it?
2. If so how much nitrous can I feed it?
I was thinking something like a Sneaky Pete.
I've never run nitrous b4 so I don't know how or at what RPM to use it at so any thoughts, tips or opinions would be appreciated.
Thanx
Brian
87 SC
Goodwrench 350 (bone stock), Hedman Hedders, High Flow Cat, Flowmaster Muffler, Accel 8mm wires (half Accel, half Discount Auto.. Darn hedders keep buring wires), rear antisway bar from T/A, strut tower brace, Gas shocks all the way around, Borg Warner Posi Disc w/ 3.70s, B&M Shift Kit, K&N.
Future Mods: Crane Powermax Cam, World Products Sportsman II Heads, Crane HI-6, Accel 300+ 8.8mm wires, new high flow cat, Borla cat-back exhaust, Custom Ram Air/Extractor hood, March Power Pulleys, Aluminum Radiator, Jet Custom Chip, and I'm gonna convert carb to TPI.
Goal ET 13.5
This car is currently off the road until its finished. I'm now driving a 94 Camaro 5spd V-6.
Old Sep 18, 2000 | 04:09 PM
maniacc's Avatar
Well if you already bought those pistons....take them back...they won't last with the blower....you need forged pistons...much more reliable...
9.6:1 compression w/o blower...and guess what???...after you install the blower it will still be 9.6:1 compression...you will just have higher cylinder pressure's...
I would also consider a forged crankshaft and rods....
just my .02
MÅN¡ÅÇ ©
88 IROC 5.7L,edelbrock TES,random tech cat,borla exhaust,chip,sfc,accel wires,airfoil,k&n's,ETC..
and soon to be supercharged
http://maniac.megamania.com
[This message has been edited by maniacc (edited September 18, 2000).]
Old Sep 18, 2000 | 09:13 PM
87SC/SS's Avatar
Thanks for the reply. I looked into all forged rotating assembly but it was really expensive. If the hypereutectics won't handle the 8lbs of boost I'll just run less boost then.... I saw on your website that you have borla exhaust.. do you have any sound clips of it?
Thanks again
Brian
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
David Frans
Oct 31, 2015 08:12 PM
tmellott89
Oct 14, 2015 02:06 PM
Giocio
Oct 1, 2015 12:20 PM
Damon
Sep 26, 2015 04:29 PM
