I need pics on twin turb 3rd gen camaros?
Old Sep 15, 2000 | 02:49 PM
superiroc's Avatar
I need pics to see how to run the plumbing etc. on my iroc. I'am going to put the intercooler in front of the radiator in the grill. Does Skultze have any pics?
Old Sep 15, 2000 | 06:50 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Check out the page at http://www.skulte.com/turbo.html.
Here ya go for easy links http://www.skulte.com/pictures.html
I've got a Spearco 2-182 core that I'm going to mount in front of the radiator. Its barely too big, so I might section out part of the unibody and weld it back in a little higher. The drivers side turbo will cross over to the pass side where it'll Y together and squeeze past the radiator into the top pass corner of the IC. It'll exit the drivers top corner of the IC and wrap back to the throttlebody. I'm going for 2" to 2.5" piping for each turbo, Y-ing to 3" into/out of the IC. I hope this helps!
Andris Skulte
Skulte Performance Designs
Z28tt-89 IROC T56 DFI Twin Turbo http://www.skulte.com
[This message has been edited by askulte (edited September 15, 2000).]
Old Sep 16, 2000 | 07:21 AM
Guido's Avatar
Car: 2000 Trans Am
Andris, how are you exhausting those things? And do you have the wastegates ran into it if there is an exhaust or is it possibly just a small downpipe off of the wastegate?
Old Sep 16, 2000 | 12:25 PM
superiroc's Avatar
Askultze
Are you running an intercooler on your car know if so do you have any pics of the intercooler. I was thinking of running the same setup that the red trans am has on your web page. it has the intake come from the front of the car into the TB from the intercooler. I was also planning on building tube headers but not sure what size to make them and whether it matters if the headers are equal or unequal lenghs?
Old Sep 16, 2000 | 01:27 PM
superiroc's Avatar
How much HP can those banks manifolds support? My goal is 700hp on pump gas@13lbs and 1000hp on race gas@20-25lbs.
Old Sep 20, 2000 | 12:29 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Sorry for the late reply... I've got the 2.75" turbo outlet necked down to 2.5" dia downpipes (follows similar routing as normal) to a 3.5" Y-pipe, cat shell, and 3" SLP catback. I'd like to make a 3" dual if I can, maybe from ovalized 4" pipe for clearance where you need to. Thats not till after the new motor (i.e. a while)
The intercooler has been sitting on the beer fridge in the garage. I need to quit work and spend more time making fun mods for the Camaro Scavenging for headers isn't a huge consideration since backpressure will be 15 to 45 psi! Volume helps. I'd suggest 1.75" or 1.875" if you want over 800 hp. I love how we can discuss these numbers, and its actually realistic. Frightening I'm shooting for similar numbers (750 hp on street gas), so I guess we'll see when we do. The design is quite ****ty, so tubular headers would be a vast improvement.
Andris
Old Sep 20, 2000 | 01:16 AM
superiroc's Avatar
I have Bill from speedway helping me and i plan on having tube headers built. Thanks for the pics and info ASkultze, much appreciated. Good luck on your iroc.
Old Sep 25, 2000 | 07:22 PM
Twin Turbo 358's Avatar
i've got pics of mine prior to the rebuild at work. email me if anyone wants to see them...
Jeff
99 T/A WS6 A4, RKSport lid & free EGR mod
88 GTA twin turbo 358, forged crank, forged H-beam rods, Wiseco reverse dome pistons, Dart Sportsman II 72cc heads, Comp Cams custom grind blower cam (.560/.586 lift, 232/236 duration), 1.6 roller rockers, TPIS mini ram intake manifold w/ Accel 58mm TB, 83 lb injectors, Accel DFI computer with variable injector controller, 2 Garrett T04B "hair dryers" with dual Garrett wastegates, TH400 tranny with BTE transbrake and Art Carr custom converter, F*rd 9 inch rear w/ 3.50 gears, and more...
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
I'llrocya
Feb 2, 2016 11:43 PM
reiderz iroc
Aug 13, 2015 04:57 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
