Need help with plans for my 383
Old Sep 24, 2000 | 05:56 PM
crazeinc's Avatar
This winter I'm building up my 350 block. I have a TRW forged flat-tops (9.6:1 CR with 64cc heads, but I'm running 70cc heads) and 5.7" reconditioned rods from a 4 bolt main '69 camaro with new bolts and I'm not sure about the crank yet, but anyways...
I'm hoping for around 500hp at the crank when it's all said and done, but I'd like to add a 150 shot to that when I'm at the track ocassionally just to play with the stuff...(maybe once a month)
Should I still be building the engine around the nitrous use with minimual usage. Please tell me what I need in order to make sure my 383 will last...
Thanks.
82 Z28
355 carb'd, Edelbrock Performer RPM package (minus heads), Hooker Super Comps, Mufflex 4" offroad y-pipe, 700r4 with B&M shiftkit, '85 IROC 10 bolt rear with Richmond 4.10's & Auburn posi unit, Lakewood 50/50 drag shocks. Shooting for 3000lbs w/ driver.
The car's website
(383 buildup this winter)
AIM: Unitedhope
ICQ: 77979548
[This message has been edited by crazeinc (edited September 24, 2000).]
Old Sep 25, 2000 | 08:43 AM
Doug2's Avatar
It's worth the money to go ahead and get a Scat or Eagle cast "steel" crank. I would'nt build the engine around the NOS usage simply because I don't like giving up HP for any reason... Especially when MOST of the time it will be run without it. 500 HP should be EASILY obtainable with a 383. Since your carbed, you don't have to worry about making the computer happy with the cam, so you could REALLY take advantage of todays more agressive roller designs but still stay reasonable on the lift #'s in order to be a little easier on the valvetrain.
Old Sep 25, 2000 | 06:43 PM
crazeinc's Avatar
Thanks Doug...you told me exactly what I wanted to hear Scat was definetly on my mind about the crank...
I think if I get one of those Progressive nitrous controllers I'm not going to worry about it too much if I retard the timing and get colder plugs...
BTW, I'm hoping a lot of that 500hp will be from the Victor Jr. 23* heads I'm planning on getting...Edelbrock states they're good from 530-580 horses right out the box! I'm thinking a matching Victor Jr. intake and a BG Speed Demon 850 w/ mechanical secondaries will get me awful close to my 500hp mark.
Any suggestions about a cam.?..I wouldn't mind running something pretty wild, because I don't drive it often enough to keep it tame for the streets
Old Sep 26, 2000 | 03:35 PM
Doug2's Avatar
I believe The Edelbrock heads a fully capable of making good power but I wouldn't simply because, from what I've heard, they require the use of "Shaft-style" rockers like the Jesel, T & D, or similar pieces.. Those damn things are $$$$$$$!!!!!!! That's why I chose the Canfield 220's...
gixxer92
Apr 12, 2022 12:09 AM
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Nervous2
Oct 8, 2015 10:53 PM
S10K20
Oct 7, 2015 06:45 PM
Amillionoh7
Sep 26, 2015 09:45 AM
