Fuel Cut?
Old Apr 2, 2006 | 06:19 PM
Treys_IROC's Avatar
Car: '89 Camaro
Engine: Blown 5.7L TPI
Fuel Cut?
My car seems to be hitting a fuel cut. I put different pulleys on it for my supercharger and i am now hitting 9.5-10 psi. I have an FMU to regulate my fuel pressure, but my fuel seems to just cut off around 4500 rpms, i only run lean for the second that the fuel cut happens, otherwize im running rich all the way to the fuel cut,and then after the fuel cut
Any Ideas as to what could be causing the problem?
Thanks for any help,
Trey
Old Apr 2, 2006 | 10:18 PM
GreenChevelleSS's Avatar
Car: 1970 Chevelle SS 396
Engine: 414ci Big Block Chevy
Transmission: Muncie Turbo Hydromatic 400
very annoying too only happens when full boost and hard pull like in second and third gear...
Old Apr 7, 2006 | 09:25 PM
wow lots of help here too bad the engines blown up now....
Old Apr 9, 2006 | 01:06 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
what pump you have and whats your fual pressure when boosting
Old Apr 13, 2006 | 01:41 PM
jocool's Avatar
Car: 89 Iroc & 88 Firecird & 86 Camaro
Engine: 350 TPI & 305 TBI & 305 Carb
I was having a fuel problem as well. I had stock intank pump with the ati inline and when I would reach the top of second gear (somewhere around 5200 rpms my fuel pressure would fall off (it would hit around 70 and then fall off). I installed a walbro intank and hot wire kit, and retained the inline pump. Problem solved, I guess the stock intank pump wasn't enough to feed my inline pump. Another thought is your FMU could be maxing out although your pressure should remain consistant(quit climbing but not drop off)if this was the problem. Just a few thoughts hope it helps.
Jeremys87
Jul 14, 2022 09:08 PM
Caspar
Jun 19, 2016 11:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
Winchester1094
Aug 18, 2015 10:23 AM
TA8487
Aug 11, 2015 09:02 PM
