NOS????
Old Nov 2, 2000 | 06:26 PM
firebird87's Avatar
NOS????
I would like to add some Juice to my TPI 305 It runs stong know with a cam and all of the bolt on you can think of. 1/4 times 13.9 at 100. Can anyone tell me the best set to go with and give me any kind of pointers to set up a good and safe system.
thank you,
Jim
Old Nov 2, 2000 | 09:42 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
I have used both NOS and Nitrous works systems and like both kits,I lean towards the NOS kits because they seem to be more complete on the installation.As for seting up the system,don't go above a 100HP shot of spray on your 305.Make sure that your fuel and ignition systems are in good working order.Almost all NOS engine failures I have ever seen has been due to inadequate fuel systems.For every 50HP of spray you run retard your timing 1-2 degrees,run one step colder spark plug than factory and everything should be ok for ya.
Superman
Rev'n to Seven
junior419
Apr 7, 2025 11:35 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
