Supercharger/ Superram recommendation needed
Old Nov 1, 2000 | 11:57 PM
tples69's Avatar
I have a 406 with a SR complete kit (DFI). I want to run a supercharger but I called ATI and Vortech, neither could help.
Has anyone installed a SC in a first gen Camaro with a Superram intake?
It seems the problem is I don't run AC or PS. I have an ARDF front suspension (manual rack & pinion) setup. Someone suggested I needed an idler pulley in place of the PS.
Any ideas?
Thanks.
Old Nov 2, 2000 | 10:27 AM
89ProchargedROC's Avatar
Were you the one who emailed me a while ago about my blower for sale? well, either way, you need to get the serpentine set up from a third gen and then you can use a third gen kit. As for ATI, you would need someone to come over who has a kit and see how the intercooler and routing could be done. I am willing to help. shoot me an email.
Old Nov 2, 2000 | 01:52 PM
tples69's Avatar
My issue is not the inter-cooler, at least at this point.
Can I run the 88-92 Camaro bracket/pulleys even though I don't run PS or AC?
Old Nov 2, 2000 | 04:19 PM
PROCHARGED89Z's Avatar
Yes you can.
Old Nov 2, 2000 | 04:25 PM
tples69's Avatar
Thanks.
Exactly what do I need to buy in order to do this?
Old Nov 3, 2000 | 02:22 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
You'll need the AC delete pulley...as for the steering pump, you can just not install it and route the belt like this: https://www.thirdgen.org/newdesign/t...ages/belt2.jpg
In that pic it shows the AC but just imagine the AC delete pulley in its place. The steering pump would normally be below the alternator. On the other side below the AC compressor the smog pump is normally there but I assume you don't care about emissions.
You'll also need a reverse rotation water pump and the correct alternator...the pulleys can be bought from any junkyard, etc.
BTW, that AC delete pulley can be bought at the dealer for around $50 dollars... ask for part #10055890. I've seen them cheaper though. Hope that helps.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
