fuel pump?
Old Nov 3, 2000 | 10:45 PM
tmoney's Avatar
fuel pump?
i am currently doing a tbi to tpi swap,i need to change the fuel pump to a higher flow pump for the tpi.my ? is will a stock replacment fuel pump be enough for a supercharger.if not what gph is needed?
Old Nov 4, 2000 | 02:17 AM
89ProchargedROC's Avatar
No, it wont. Get an extra in-line fuel pump and then you should be fine. i would say a stocker and say a vortech t-rex pump (very common) could easier flow enough fuel in a third gen for 500hp or maybe more with bigger injectors
Old Nov 4, 2000 | 09:09 PM
tmoney's Avatar
so i could keep my tbi fuel pump and put in a inline pump?
Old Nov 5, 2000 | 02:44 AM
GTARob's Avatar
http://members.home.net/syclone/APE/fuelpump.html
Check this address. Walbro pumps are very good and very affordable. The 255lph in tank pump is only 108+shipping.
1989 GTA TRANS AM
305 TPI, 5 SPD
SWAPPING TO TPI 350 NEXT MONTH.
Old Nov 5, 2000 | 03:43 PM
yep, you can keep your current TBI pump and just add an in-line pump. Also, if this isn't enough fuel for the blower and you dont want to perform the switch for antoher in tank pump, which is labor expensive, you can buy Kenne Bell's Boost a pump. all it does is send about 15volts to the pump so it flows more fuel. it works too, my friend has it done to his 9 second camaro and he likes it.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
