Compression Ratio
Old Nov 14, 2000 | 09:04 AM
camaroracer1992's Avatar
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
Compression Ratio
I am currently looking at Summit's engine rebuild kits in their new catalog. All of these engine kits list the head volume as 64 cc and I have 76 cc heads I know that my ratio will be lower, but by how much? The two kits I am looking at have the following ratio's.
10.9 with 64 cc, what with 76?
12.2 with 64 cc, what with 76?
I need to know because I still plan to use pump gas, and the max around here at the local stations is 94 octane, (Sunoco). Thank you very much
Old Nov 14, 2000 | 06:54 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
compression depends on more than head cc, like dishes pistons and head gasket thickness. Id say u lose alomost a point of compression going from 64-76cc heads. that Is a very rough estimate though. The less valve relief in the piston that you have, the more change youll see between the head sizes.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
