Willie, do you have single fan?
Old Jan 11, 2001 | 03:01 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
I was just wondering if you have the stock single, dual or an aftermarket cooling fan assembly? What is the fit around it like with the procharger drive belt?
Tracy /AKA IROCKZ4me
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
Club IROC-Z
Old Jan 11, 2001 | 06:51 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Tracy,
I have the factory dual fan setup. I also have the D1SC kit, which includes a 12-rib belt (about 1-1/2" wide). It is a tight fit, but clears everything.
My only concern is the upper radiator hose. It must be cut so the 90 degree elbow at the radiator inlet must be made as tight to the radiator as possible. It must also be secured by a tie down to the upper radiator support bracket to prevent it from contacting the 12-rib belt. This looks like of cheap.
Willie
Old Jan 11, 2001 | 08:39 AM
IROCKZ4me's Avatar
Thanks, While you go through your install I am seeing what I get to look forward to.
I might be in for some core support mods then, since I'm using a thick Be Cool radiator.
I'd be willing to bet you could fab up a strap that connected to the factory hose support that looks better than the tie down on it now.
'86 IROC-Z Camaro
  • 355 cid
  • AFR heads
  • fully balanced
  • SLP cat-back
My IROC-Z
Club IROC-Z
sheachopper
Jul 31, 2019 11:27 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
dusterbd
Sep 29, 2015 08:40 AM
