will a 650 dp be enough
Old Jan 10, 2001 | 12:06 AM
JJ's Avatar
JJ
I have a 350, around 350 hp, with a holley dp. Fuel and ignition are top notch, will this carb. support a 100 - 150 shot, or should I be looking at something to feed it a little more ?? thanks
87 IROC, 350/5 speed. gmpp 350, vortec heads w/some work, XE268, 1.5rr's, 650dp, rpm intake, MSD ing., ect.
89 formula, L98.
Old Jan 10, 2001 | 05:38 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
If you're talking about a 100-150 HP shot of nitrous?...Then your carb will be just fine. The carb doesn't supply either fuel or air for the nitrous system. The nitrous system simply adds to the mixture that the carb is already supplying. The fuel pump, lines & filter are the limiting factor, not the carburetor.
Tracy /AKA IROCKZ4me
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
Club IROC-Z
Old Jan 10, 2001 | 09:25 AM
JJ's Avatar
JJ
oops, I thought that the carb had to compensate, but since you mentioned fuel supply - I'm running stock 3/8" lines and am wondering about the fuel filter. I have a car that was tpi and still has the inline tpi filter, now the car is carb, will this filter impede a lower pressure pump (holley red pump plumbed inline) since it (filter) is designed for high pressure use ?? thanks
Old Jan 26, 2001 | 11:39 AM
IROCKZ4me's Avatar
Sorry about the long delay. I didn't notice your reply before and haven't been online as much lately.
Those should be fine up to around 450-500 total HP range. They become marginal there. If you will be running higher HP ½" tube would be a good idea. You can get 25' for around $20-$25 + fittings.
Another fix would be to use a high pressure EFI type intank pump. The higher pressure will force more fuel through the smaller diameter tube. Then use a good FP regulator before the carb & fuel solenoid to drop the pressure.
A stock TPI filter should be fine as long as it is fresh. There isn't much restricion there. The housing is just made to withstand higher pressures without bursting.
Be sure to keep it fresh though. Higher pressures will push more fuel through a dirty filter than low pressures will.
'86 IROC-Z Camaro
  • 355 cid
  • AFR heads
  • fully balanced
  • SLP cat-back
My IROC-Z
Club IROC-Z
[This message has been edited by IROCKZ4me (edited January 26, 2001).]
ZZ3Astro
Aug 13, 2019 12:57 AM
bbsr72
Apr 2, 2016 09:12 AM
beastin91rs
Oct 9, 2015 07:38 AM
Chad Speier
Sep 24, 2015 12:32 PM
buckshot63
Sep 10, 2015 09:15 AM
