Attn: Firebird /Paxton guys
Old Jan 31, 2001 | 01:25 PM
theformula's Avatar
Installing a Paxton in my 1le right now. Where the heck do I install the air filter. Do I have to re-locate my battery to the passenger side?
91 Formula
305 TPI 5speed
1LE/G92/WS6
w/GTA gfx,rims,hood
Paxton 10lb blower, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires, fastchip, Bosch O2sensor, SLP headers & catback,short shifter,3:73s w/Auburn posi,160* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Feb 1, 2001 | 06:21 AM
Blown 305 TBI's Avatar
Well I have a 92 and my battery is on the passenger side stock. I'm not sure if that's because yours is a 91, or maybe because mine's TBI.
But whatever the reason is for yours being on the drivers side, I would say that you most likely have to relocate your battery someplace other than where it's at. That's where the intake for my Paxton comes from, the cone filter is mounted under the fender and the tube comes up along in between the winshield washer fluid tank and the S/C, does a 180* turn and connects to the back of the S/C.
Since it looks like you have to relocate your battery I would just go ahead and relocate it to the hatch/trunk area. Better weight distibution, more room in the engine compartment, and you can order the kit to do it from Summit for $43.
Good luck,
Mike
BRoss99
Aug 10, 2025 05:08 PM
jhawkeye
May 25, 2022 06:33 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
Street Lethal
Aug 14, 2015 08:25 PM
