Fuel Lines
Old Feb 7, 2001 | 04:31 PM
Havoc's Avatar
Fuel Lines
Is it possible to use the return line as an additional fuel line for a NOS system.The car came factory with a carb. Im currently using a block mounted pump with no return. So was wondering if I could mount a elecric pump back by the tank on the retun line and take that straight to the NOS solenoid.Just a thought since the retun line is currently not being used.
Old Feb 7, 2001 | 07:28 PM
87formula383's Avatar
YES, If and only if:your car has a canister purge line going to the tank, or you have an old vent type gas cap...also, the NOS kit must be designed for that type of fuel pressure...P.S. be carefull,make small 1 second shot tests in 2nd gear to start off when initally testing it.
Old Feb 7, 2001 | 10:07 PM
Havoc's Avatar
Please explain in a little more detail.Are you currently running the same setup
Old Feb 9, 2001 | 07:38 PM
Details:what type...is your system a power shot set up for a carb. then all you need is 6 to 8 pds. of fuel presure.those kinds of details...and no,my current car is PFI with a home made NOS system...I had a 69 elcamino with a carb and the NOS power shot system you probably have.
Old Feb 10, 2001 | 09:41 AM
Havoc's Avatar
Yes my setup is the NOS super power shot thanks for the info.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
