N20 and high compression
Old Feb 3, 2001 | 06:17 PM
Havoc's Avatar
Im currently running .180 domed pistons in my 355, and was considering the NOS super power shot. would I have to retard more timing due to the higher compression.What other problems would could any foresee. My ignition is all MSD including 6a box and probillet distributer.The cam is the Edelbrock Performer RPM which is pretty big.I almost forgot I'm currently running a set of pocket ported 931 iron headswithch gives me about 10.5to 1 compression. Please Help.
Old Feb 3, 2001 | 06:21 PM
Havoc's Avatar
Sorry fo the horrible grammer in above post. Would my Holley mechanical fuel pump be good enough or would it be time for an upgrade.
Old Feb 4, 2001 | 01:35 AM
burnoutrpm's Avatar
dont know much on NOS(yet) but do know this...nos and high compression is possible but, that compression shouldnt be tooo much of a prob people run 13:1 compression and nos alll the time!!(my friends doing it!) i think you just re-jet and supply more fuel i think!!? email me at
burnoutrpm@hotmail.com and let me in on what you find out!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 160 (882) heads,.447/.447 lift 222@.050 duration speed pro 327/350hp cam 350 .40 over (356) Edlebrock torker2 and a 600 edlebrock manual choke (1405)
Future mods performer rpm air gap intake (polished) comp roller cam, and way better headsa 400 defintely in the works!
Old Feb 4, 2001 | 04:21 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
You should be fine with around 10:1. Things don't usually get too hairy until over 14 or 15:1 and then finding fuel with high enough octane becomes a factor. also the heat and pressure get harder to handle. I do know a guy that has run 16:1 compression with big shots of nitrous for over two seasons with no problems.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
Club IROC-Z
Old Feb 6, 2001 | 12:37 AM
Havoc's Avatar
BTT
Old Feb 18, 2001 | 03:28 PM
The ODB's Avatar
combustion is more efficient with higher compression ratios & higher cylinder pressure. More efficient combustion requires less spark advance to make maximum power. The same holds true for N2O.
You will just need to run a little less advance depending on how lean you run and how much N2O you use.
Less advance does NOT mean less power.
FormulasOnly
Jul 23, 2018 08:47 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
sammy52401
Nov 11, 2015 07:20 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
