Wastegate for supercharger
Old Feb 20, 2001 | 12:58 AM
IrocZ335's Avatar
Would a wastegate be able to standup to the pressure of the boost after a supercharger? I read in another post that wastegates were designed for one thing only and that a bypass valve is used on the boost side of the turbo. I know there are adjustable bypass valves made, but you usually have to change springs to set the boost level, not just turn a ****. I also thought that a bypass valve was designed to release all the pressure when the throttle was closed so the air pressure wouldn't be reversed into the turbo or supercharger. If you could put a wastegate on the boost side of the supercharger then you could control the boost. I thought about putting a wastegate on the intake side of the supercharger but the intake air isn't pressurized so it really wouldn't have the same effect. If you could control the boost from a supercharger you could essentially run the engine naturally aspirated. Just a thought inspired by another post, if it wouldn't work, no big loss.
1986 Iroc Z 305
3.23 posi-rear
ported mass-air
custom ram-air
removed air pump, converter, straight pipe no muffler
0-60 5.5 sec
1/4 mile at 102mph
top speed 160mph (racing a mustang)
est 285hp
fiberglass hood
$2000 Alpine stereo hit 135 in spl comp.
toronto formula
Nov 10, 2015 06:17 AM
customblackbird
Oct 1, 2015 04:30 PM
-=Z28=-
Sep 24, 2015 10:21 AM
Nick McCardle
Sep 10, 2015 08:36 PM
