Carb. Nos kit to TBI, whats needed?
Old Feb 25, 2001 | 11:39 AM
Zar's Avatar
Zar
IF I am going to by Nos then I rather get a carb. kit to save money. Is it easy to change it to work on TBI? Do I just change the plate and the solenoids? thanks!
Old Feb 25, 2001 | 12:22 PM
The ODB's Avatar
If the plate fits on your intake then it will work.
you should use a high pressure or braided line on your fuel supply to the fuel solenoid & know what that pressure is.
To adjust for the much higher fuel pressure you just run smaller fuel jets. You can use NOS's recommendation on fuel jet, or just lean it down until you're happy.
If you don't want to blow an engine in the process, then monitor your O2 and sparkplugs while tuning it.
1992 Trans Am
May 10, 2023 07:19 PM
MustangBeater20
Oct 29, 2022 09:20 PM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
